well, just to say that the Teac went down well as a prezzie - was viewed as good looking and a good size, and simple to operate - I think she was talking about the radio ;-)
not wholly convinced of sound quality but am not voicing thought about that out loud - mind you, its the first experience I have of DAB.
Only five presets for the FM and five for the DAB - or perhaps 10, I'm not sure yet. But that adds to the 'simple to use' feel. its easy to jog to other stations.
The major bonus is the built in rechargeable battery, which gives it its weight, as dab drains power more than FM, and so it really is portable, or luggable. It has stereo headphone and mono speaker, with an Aux feed to take MP3 player and the like.
It lacks digital out, and has none of the pause/store/re-listen facilities that some others now offer.
It has clock, sourced from digital signal, and could be used as alarm clock/radio.
If I take to dab, then next up will be upgrade to ageing clock/radio in bedroom. Might then go for a mains only type which would give wider choice, bringing the Tivoli range into consideration. I had a look at the Pure Evoke 2xt and the Evoke 3 when out shopping yesterday. All the bells & whistles there and maybe nearest to hifi, so I might indulge but we'll wait and listen first. Both are quite sizeable and the re-charge battery an extra £30, or else expensive consumption of a 6-pack, so they were not sensible buys this time around.
