Wee bit of a different scenario?
Balanced mains transformer power supply..
Heard the benefits in my system, getting one delivered.
My mains are crap so will clean things up a lot.
BACKGROUND INFO:
Hard wiring my system to one of THESE:
http://www.airlinktransformers.com/s...1-BPS2020.html (with RCBO protection on the secondary power leg)
4 bits of kit hardwired to balanced trannie; Valve amp, Young Dac, Music sever (PC) and plasma TV.
It will be wired up like this:
Wall Socket -> "Mains cable" -> Input terminals of balanced supply
Output terminals of balanced supply -> "mains cable" -> 60A JUNCTION BOX (HARDWIRE IEC MAINS LEADS FROM EQUIPMENT INTO IT) -> Hifi Kit.
QUESTION:
For the "Junction Box"(To enable hardwiring..eliminate as many fuses as possible!) will something like THIS be ok?
http://www.tlc-direct.co.uk/Products/AAJB60.html
THINKING THIS JUNCTION BLOCK WONT ACCOMODATE 5 OR 6 SEPERATE IEC CABLES FROM MY KIT THOUGH?
READ UP ABOUT THE NAIM HYDRA...GOOD PRINCIPLE BUT THAT TERMINATES IN A 3 PIN PLUG, I WISH TO CONNECT TO THE OUTPUT TERMINALS ON THE TRANSFORMER.
ALL WORK WILL BE CARRIED OUT BY A SPARK, SO NO WORRIES.
Also,
CHOICE OF MAINS CABLE BETWEEN WALL > BALANCED TRANNIE > DISTRIBUTION BOX
I have lots of Lapp Oflex CY Classic cable I was thinking to use...
http://lapplimited.lappgroup.com/pro...ic-110-cy.html
but I wonder if theres any milage in going for any other cable apart from the Lapp?
Thinking:
http://www.fscables.com/Power/Fixed+...hield/list.htm
or
http://www.jobarco.com/files/sheets_en/EMC-FLEX-e.pdf
or even (as I only need a couple of metres) Furutech or Oyaide!
Any links to DIY builds of similar or info greatly appreciated.
Thanks!
BACKGROUND INFO:
QUESTION:
Also,
Thinking:
or
Thanks!
