...coming on nicely. Just got to get a motor and PS sorted (hence the wait for more money!). After so many useless motors I am going to go for a brand new LP12 job as I am using a Linn subplatter. I am going to go with belt drive for the momment but with the possibility of converting it to idler drive.....not sure yet, I would have prefered a more powerfull motor if going that route, we'll se what it sounds like first. Main plinth is made up of 4 layers of 18mm birch ply and is veneered with burr oak. I am still looking for some suitable (soft) isolating feet that are adjustable. Outer platter is a Thorens TD160, much cheaper than a Linn item. The center needed releiving slightly (wet and dry did the trick) and I will have to make the level up with the mat as it sits too low on the Linn sub platter. Sub platter is 2 bits of 12mm acrylic and it sits on some carbon isolators. The motor will be mounted directly on the birch ply plinth thus hopefully giving decent isolation but with a nice direct drive path. The motor sits closer to the sub platter than on a LP12 so I will have to sort out a shorter belt. [IMG]http://img506.imageshack.us/img506/8273/dscn03154xj.jpg[/IMG] [IMG]http://img503.imageshack.us/img503/6296/dscn03185st.jpg[/IMG] [IMG]http://img204.imageshack.us/img204/7291/dscn03204uq.jpg[/IMG] Paul.
