Fader knob suppliers
Discussion in 'Pro Audio' started by Lorin David Schultz, Jan 17, 2006.
  1. I want to replace some of the fader knobs on my Soundcraft Delta with
    different colors. Anyone know who sells stuff like that in small
    quantities? My Google search turned up nada, and Soundcraft doesn't
    have any left.
    A supplier in Canada would be ideal, but other countries are fine too.
    "It CAN'T be too loud... some of the red lights aren't even on yet!"
    - Lorin David Schultz
    in the control room
    making even bad news sound good
    (Remove spamblock to reply)
    1. Advertisements
  2. Lorin David Schultz
    mainmachine Guest
    REAN makes 'em in a whole bunch of different colors, and they're
    available through mouser.
    -daver
    mainmachine, Jan 17, 2006
    1. Advertisements
  3. Lorin David Schultz
    Pooh Bear Guest
    They were likely made by Sifam.
    http://www.sifam.com/sliderknob_intro.lasso
    You may not be able to get the original pattern but I'm sure they'll be
    able to help.
    Graham
    Pooh Bear, Jan 17, 2006
  4. Ding ding ding! I was just coming here to post a follow-up, and there's
    Graham with the right answer.
    They are Sifam knobs. The question now is who sells these things?
    Google has been a whole lot less than helpful in this whole endeavour so
    far.
    in the control room
  5. Anyone know who sells Sifam fader knobs in Canada? How about the USA?
    I haven't been able to find a dealer who actually carries stock... I
    want to buy ten or twenty, not two thousand.
    Thanks for any leads/tips!
    in the control room
    Lorin David Schultz, Jan 23, 2006
  6. Lorin David Schultz
    Ron(UK) Guest
    Not in Canada, but Canfords in the UK sell Sifam round knobs and Rean
    fader knobs to fit most if not all common sliders, They also do
    international sales, it might be worth dropping them an email.
    Ron(UK)
    Ron(UK), Jan 23, 2006
  7. i buy Sifam buttons from Selco in California. But I generally have to
    buy 1000 pieces at a time. If you happen to want what they happen to
    have, they'll sell you smaller quantities. But most of the time, you
    can't buy what doesn't exist so you have to order 1000 pieces because
    that's what it takes to get Sifam to manufacture them.
    ulysses
    Justin Ulysses Morse, Jan 24, 2006
    1. Advertisements
