My theory, for which i have no scientific background whatsoever, was to bond the top three tiles together in such a way that they are close enough to give a very stong bond and give the structure as a whole very good structural integrity. the use of silicon adhesive was because it is an excellent bonder, and as long as the layer isn't too thick it is fairly rigid. the differing layers would hopefully break up any standing waves. When using the silicon you need to lay a bead around the front and two sides , leaving the back open, you then lay beads from front to back. all of the silicon needs to come into contact with air otherwise it will not set. if you use a two-pac chemical reaction type adhesive then contact with air is not essential.
Maybe a more complex mix of materials is something to try in the future, or for somebody else to have a go at. My little block has granite, silicon rubber, plywood, aluminium, air , laytex type rubber and Blu-Tac in the mix, theat'll do for me for the time being.
i am getting the effect i desired when i first started this little DIY project, so I can't see me taking it much further, at some point in the near future i will whip out the Tube just to see if i notice a huge difference. I think that sometimes i have been a bit too quick fire in my A-B comarison demo's in the past. Far better to live with something for a while and then make a change, that way you get more of a 'Where the hell did the second guitar go ?!'
type effect or even better 'where the hell did that guitar come from !?
. If you see what i mean.
