Hard drive reads okay, writes slow
Discussion in 'Cakewalk' started by Steven Bell, Dec 30, 2003.
  1. Steven Bell
    Steven Bell Guest
    Here are the Catena dskbench results. Note the initial "write" time!!!
    Steven
    K:\Temp>dskbench
    DskBench 2.12
    (c) 1998, SESA, J.M.Catena (, www.sesa.es)
    Timer Check = 1000 (should be near 1000)
    CPU Check = 0.63 % (should be near 50.00 %)
    CPU index (relative to Pro 200 MHz) = 8.701599
    Open = 0 ms
    Write = 26297 ms, 9.73 MB/s, CPU = 0.11 %
    Flush = 16 ms
    Rewin = 0 ms
    Read = 9031 ms, 28.35 MB/s, CPU = 0.56 %
    Close = 0 ms
    BlockSize = 131072, MB/s = 9.21, Tracks = 109.55, CPU = 0.04 %
    BlockSize = 65536, MB/s = 6.54, Tracks = 77.73, CPU = 0.09 %
    BlockSize = 32768, MB/s = 5.03, Tracks = 59.75, CPU = 0.30 %
    BlockSize = 16384, MB/s = 3.79, Tracks = 45.11, CPU = 0.57 %
    BlockSize = 8192, MB/s = 3.07, Tracks = 36.46, CPU = 0.98 %
    BlockSize = 4096, MB/s = 2.40, Tracks = 28.54, CPU = 1.60 %
    1. Advertisements
  2. Steven Bell
    Kevin Perry Guest
    More to the point that access to audio data is fairly random (as in, if you're
    reading 16 waves, the head is jumping around anyway), so statistically, you're
    better off not defragmenting. There was a great article a few years back on
    StorageReview (I think) where a random access file server was tested before and
    after defragmenting, and the fragmented drive was faster because of the random
    nature of the access - the same applies to the way we pull audio from drives.
    Kevin Perry
    The Mountain Grill
    http://www.mountaingrill.co.uk/
    "It is the business of the future to be dangerous;
    and it is among the merits of science that it equips the future for its duties."
    Kevin Perry, Dec 31, 2003
    1. Advertisements
  3. Steven Bell
    Steven Bell Guest
    How about defrag before a live 16-track recording, but not during post?
    Steven
    Steven Bell, Dec 31, 2003
  4. Steven Bell
    C Hudson Guest
    hmm, I doubt that for audio though. I remember several examples wher a file
    stuttered and gaged during play back until the wave drive was defragged.
    From as far back as PA 8.
    That tests results do not explain why it worked for me. hmm....
    C Hudson, Jan 3, 2004
  5. Steven Bell
    Jose Catena Guest
    Perhaps the disk has write verify enabled. Some come this way from factory.
    If so, DL an utility from the manufacturer to switch it off.
    In some cases, write verification is switched off automatically after a
    certain period of use.
    Software write verification can also make it happen, be sure the OS is not
    doing it.
    Some antivirus software can also slow down writes. Don't install resident
    file monitors in a DAW.
    There is yet another possible reason for slow write speeds: when a fast disk
    is operated at lower ATA speeds than it was designed for, this may happen.
    Jose Catena, Jan 3, 2004
  6. Steven Bell
    Jose Catena Guest
    Hey, that's our Jose Catena! Small world.
    Our? What do you mean saying "our"? I'm a cheap guy, but you didn't pay the
    fee yet! <g>
  7. Steven Bell
    Steven Bell Guest
    Thanks, Jose'.
    I don't know how to see if a disk has "write verify" enabled. I did not
    install any special software when I installed these.
    I have not seen a write verification switch in Windows XP, either. Do you
    know where to look?
    I'm using Norton AV 2003 with everything disabled (AFAIK) other than email
    checking.
    I suppose I can manually stop all of the NAV services and re-test.
    According to BIOS setup the drives are set up for DMA mode 5. It also lists
    a PIO mode in BIOS so it's hard to tell which one is used by the OS. Do you
    know a way to verify which mode a disk is in (within Windows)?
    Excellent ideas, BTW. I'm going to keep them around in case this happens to
    someone else.
    Steven
    Steven Bell, Jan 3, 2004
  8. Steven Bell
    Jose Catena Guest
    What's the disc's brand and model?
    The first thing you need is the manufacturer utility to check/disable write
    verify.
    XP does not have write verify switch AFAIK.
    To see the ATA mode being used, see the properties of the disk controller in
    device manager, but surely it will be DMA5.
  9. Steven Bell
    Alan Le Guest
    Man... I would've never thought to check that, and it has even happened to
    me before (WD drive)! Write verify absolutely kills performance. There's
    probably a utility available from the manufacturer, and it likely needs to
    be run from DOS.
    It should tell you in the properties for the IDE channel in Device Manager.
    Alan
    Alan Le, Jan 3, 2004
  10. Steven Bell
    Steven Bell Guest
    They are Seagate Barracuda's ST380011A and ST380021A (Master and Slave).
    I'll take a look for that utility.
    Thanks again, Jose',
    Steven
    1. Advertisements
