Toshiba
The methods discussed first in this section are used to run the BIOS Setup routines on Toshiba laptop systems for the following Toshiba models:
All Libretto, all Portege, Satellite 100CS, 105CS, 105CT, 110CS, 110CT, 115CS, 115CT, 1555CDS, 200CDS, 205CDS, 2060CDS, 2065CDS, 2065CDT, 2100CDS, 2100CDT, 2105CDS, 2140XCDS, 2180CDT, 2210CDT, 2210XCDS, 2250CDT, 2250XCDS, 225CDS, 2500CDT, 2505CDS, 2505CDT, 2510CDS, 2515CDS, 2530CDS, 2535CDS, 2540CDS, 2545CDS, 2590CDT, 2595CDS, 2595CDT, 2595XDVD, 2615DVD, 2655XDVD, 2675DVD, 2715DVD, 2715XDVD, 2755DVD, 2775XDVD, 300CDS, 305CDS, 305CDT, 310CDS, 310CDT, 315CDS, 315CDT, 320CDS, 320CDT, 325CDS, 325CDT, 330CDS, 330CDT, 335CDS, 335CDT, 4000CDS, 4000CDT, 4005CDS, 4005CDT, 4010CDS, 4010CDT, 4015CDS, 1805-S177, 4015CDT, 4020CDT, 4025CDT, 4030CDT, 4060CDT, 4080CDT, 4080XCDT, 4085XCDT, 1415-S115, 1415-S105, 2410-S204, 1410-S174, 2410-S203, 1410-S173, 1415-S174, 1415-S173, 1405-S172, 1405-S171, 1400-S152, 2400-S252, 2400-S202, 2400-S251, 2400-S201, 1400-S151, 2405-S202, 1405-S152, 2405-S221, 2405-S201, 1405-S151, 4090XDVD, 4100XDVD, 2800-S201, 2805-S201, T2100, T2100CS, T2100CT, T2105CS, T2105CS, T2105CT, T2110CS, T2115CS, T2130CS, T2130CT, T2150CDS, T2150CDT, T2155CDS, 2800-S202, 2805-S301, 2805-S401, 2805-S202, 2805-S302, 2805-S402, 1805-S203, 1805-S253, 1800-S203, 1800-S253, 2805-S503, 2805-S603, 2590CDS, 2590XDVD, 2695DVD, 220CDS, 2545XCDT, 1805-S273, 1805-S204, 1805-S254, 1805-S274, 1800-S204, 1800-S254, 2060CDT, 1800-S206, 1800-S256, 1805-S255, 1805-S154, 1805-S207, 1800-S207, 1800-S274, 1805-S278, 1805-S208, all Satellite Pro, all TE-Series, and all Tecra
There are three ways to run the BIOS Setup on these models:
From Windows, using the HWSetup program—The HWSetup program comes preinstalled on these Toshiba models, and it is also contained in the Toshiba Utilities package for these models, which can be downloaded from the Toshiba support Web site. To run HWSetup, open the Control Panel and double-click the HWSetup program. If you change any settings, you may be required to restart the system.
Starting with the system powered off (not in sleep/suspend or hibernate mode)—Start with the system powered off. Press the power button and then immediately press and hold the Esc key while the system runs the POST (Power On Self Test). When the POST finishes, a prompt will appear telling you to press the F1 key to enter BIOS Setup. At that time, press the F1 key to access the BIOS Setup program.
From MS-DOS, running the TSETUP program—TSETUP must be run under MS-DOS mode and not in a DOS session under Windows. The TSETUP utility will not work if a memory manager such as HIMEM.SYS, QEMM386, or equivalent is installed. TSETUP comes with the software provided with the system, or it can be downloaded from the Toshiba support Web site.
The next method discussed in this section is for the following Toshiba models:
Satellite 1605CDS, 1625CDT, 1675CDS, 1695CDT, 1715XCDS, 1735, 1755, 1730, 1750, 3005-S303, 3005-S403, 3000-S353, 3005-S304, 3000-S304, 3000-S307, 3005-S308, 1005-S157, 1000-S157, 1005-S158, 3005-S307, 3000-S309, 1905-S277, 1000-S158, 1200-S121, 1200-S122, 1905-S301, 1955-S801, 1955-S802, 1100-S101, 1905-S302, 1105, 1115-S103, 1905-S303, 1955-S803, 1905-S304, 1955-S804, 1110-S153, and 1115-S104
These models use a Phoenix BIOS. To access the BIOS Setup on these systems, the system must be off, and not in sleep/suspend or hibernate mode. Press the power button and then immediately press and hold down the F2 key. When the POST (Power On Self Test) finishes, the BIOS Setup screen will appear.
The final method discussed is for the following Toshiba models:
Satellite 5005-S504, 5005-S507, 5005-S508, 5105-S607, 5105-S608, 5105-S501, 5105-S701, 5105-S502, 5105-S702, 5105-S901, 5205-S503, 5205-S703, 5205-S504, and 5205-S704
These are "legacy-free" models, and they do not incorporate a BIOS Setup program in the motherboard ROM. The only way to run BIOS Setup is using a Windows-based BIOS Setup utility called HWSetup. The HWSetup utility comes preinstalled on these Toshiba models, and it is also contained in the Toshiba Utilities package for these models, which can be downloaded from the Toshiba support Web site. To run HWSetup, open the Control Panel and double-click the HWSetup program. HWSetup provides a graphical front end for modifying BIOS settings. Note that if you change any settings, you may be required to restart the system.
