how to play more vsti's on the same time in real time?
Discussion in 'Cubase' started by dolphin, Jun 29, 2003.
  1. dolphin
    dolphin Guest
    i need to hear different instruments in real time in cubase vst 32
    i only can select one track( i think)so i only can hear one instrument at
    the time.
    is there a solution to hear more at the same time with only one external
    midi keyboard???
    greets
    dolphin
    1. Advertisements
  2. dolphin
    Yup Guest
    set all midi tracks you want to hear to the same channel number?
    SinQ
    Yup, Jun 29, 2003
    1. Advertisements
  3. dolphin
    dolphin Guest
    Yup i did ,but i only hear the selected track
    greets
    dolphin
  4. dolphin
    Vic Emerson Guest
    In VST, make sure that the Track/Part Inspector is open (at the left of the
    Arrangent Window). Then click on the little arrow just to the right of the
    words "Track (or Part) Info". the Inspector will then expand, and now just
    underneath the arrow you will see a pop-up "Multi Out"..click on it and select
    "Add Out".This creates another "Layer".You can now assign it to whichever
    output (including VSTi) you choose, or indeed set any other Play Parameters in
    the Inspector, relative to that layer. Now anything you play live on that track
    (or anything recorded on that track) will play out to each layer in parallel.
    Vic Emerson, Jun 29, 2003
  5. dolphin
    dolphin Guest
    ok thnx i will try it
    greets
    dolphin
  6. dolphin
    dolphin Guest
    OK guys thnxs ,it works
    dolphin
  7. dolphin
    GetVSTwise Guest
    Activate multi record and select layer as option.
    Go to Options > Multirecord and activate it.
    Then make sure Layer is ticked on the same sub menu.
    A new column "R" appears. Select as many tracks as you want with their
    outputs set to different VSTi's.
    Kindest regards
    The GetVSTwise Team
    Get the 10 Hours Cubase Video Manual from
    http://www.getvstwise.com
    Subscribe to the GetVSTwise Newsletter at
    http://www.getvstwise.com/news/letter.htm
    GetVSTwise, Jun 30, 2003
    1. Advertisements
