Wanted: Interconnect Cable Offcuts
I'm planning to build some very short interconnects (say around 8 inches) between my pre and power.
If anyone has any spare short lengths of decent cable (e.g. GWS-type stuff or better) then drop me a pm.
Or any decent interconnects that have been damaged which I can salvage 8 inches of good cable from.
Or indeed any recommendations for quality cable I can use for the planned task.
At the moment it looks like I'll be using the Great White Shark cable from Maplin
I've got a bit of Musical Fidelity Nu-vista interconnect cable kicking around, you can have it for free, pm me if you want some.
John
John - I finally made up my long set of NuVista ICs from the cable I got from you a while back - using Bullets. Soldering the Bullets on them was pretty straightforward. However, I have a question (may have asked you this before but can't remember): I only soldered the outer braid to the return pin and cut the inner braid and copper foil back. Now I'm thinking it might have been better to solder just the inner braid, or even the two braids together...? What do you normally do?
Still have enough left for another short (80cm) IC :)
Cheers,
Hi Michael
Good to hear that you have finally made them up! Based on what MF did with their interconnects I connected both of the screens at each end. The worst thing is unravelling the screens to give you a nice small tidy amount of wire to play with. Once you've unravelled the outer screen, cut away the excess and then remove the inner white insulation and unravel the inner screen, removing most of it again and then twist the 2 screens together to form a nice tail that can be easily soldered.
I thought about the various ways it could be done, connected at both ends, connected at source only etc etc but never got around to doing any real tests though.
Best Regards
John
