Having been recently busy re-decorating and fitting new lights in the lounge - and with it the inevitable trips to the fusebox to replace blown fuses I thought I'd take a look at the 30A fuses that supply the mains to the power points in the house. Both the fuses and the holders were very dirty with oxidation having built up over the years (I suspect these were the original fuses put in when the house was built 20 years ago). In the spirit of intrepid investigation as every hifi nut should have, I decided to clean the fuses and holders with De-oxit to get rid of all the crap and give better electrical contacts. With clean shiny fuses back in place I settled down for a listen. The result? :mana: I really must investigate replacing the fusebox with a proper consumer unit and putting some spurs in. Conclusion :- The mains is important guys, if you want to maximise performance!
