Okay Henry,
Living with ESLs. You've heard enough about the positives (particularly from me!) but I'll just list them briefly again.
1. No crossover distortion
2. No box colouration
3. No driver overhang, breakup or distortion
4. They excite fewer room nodes
5. They use a single driver
6. They can be placed against side walls
7. They are as dynamic at low spls as they are at high spls (great for late night listening)
In summary, what his means is that compared to most box speakers, you will get a full range, phase coherent, lightning fast sound where you are listening to the music and not the box, cone or crossover.
The negatives are;
1. They need to be at least 3ft from the front wall
2. To get the deepest bass, you need large panels which aren't particularly discreet!
3. They won't go as loud in absolute spl as a cone, but by this stage, your hearing will be suffering and the room is so pressure loaded that you'd be better off with the ICE and Max Power brigade.
4. They don't like dust, smoke or humidity
5. They need servicing every 15yrs (but then again, most dynamic speakers deteriorate over time too).
6. The voltages inside can kill (same as with valve amps I guess) and because of their construction, aren't the best choice if young children are in the house.
7. The sweet spot can be narrow
So how will they sound, coming from cones'n'domes?
The first thing that strikes you is the top to bottom coherence of the sound. It's as if the music is cut from the same sonic cloth. The spatial cues are there in abundance to satisfy the round earther in you. You want soundstage depth, width, imagery, sense of venue etc? You got it. You want the speakers to disappear? Even with your eyes open, it's virtually imposible to pinpoint the speakers as the source of the sounds you're hearing. They'll give you all the PRaT and emotive drive you could wish for too, provided your upstream equipment is up to it.
The next thing that you'll notice is that, particularly on acoustic work, instruments sound much more true to life. Whether it's the timbre of strings, the rasp of brass, the attack and decay of percussion. It's all there. And not just with symphonic works. Merlin feels that 'stats don't do dynamics or energy. I disagree in principle but not with his interpretation (which is personal to him, I would add), and here's why.
Much of the drive and energy we associate with dance music and electronica is due to the bass distortions and colourations inherent to the reproduction of the music. Our ears are educated to accepting this distortion as normal. The single greatest shock when listening to 'stats comes when you play a familiar piece of non-acoustic music and the colouration (perceived as energy, I believe) is gone. I noticed this the first time I heard 'West End Girls' on the ESLs. The driving synth line was just that, a driving synth line - but without the attendant smearing which I had been used to. ESL bass, compared to cone bass, sounds subjectively quicker, tighter and lighter. There is no smear, bloat or overhang but I would contend that the presentation is more correct. Some may not find it as pleasurable but then again, we all choose our colourations and euphony. I think that the some people are put off 'stats by this conditioning which takes a while to break (a couple of weeks in my case).
For those who haven't heard ESLs, the closest analogy I can come up with is that they they sound a lot like a good pair of headphones - which is no surprise really since they share a lot of their design attributes with 'phones! So for those of you who wish you could get the headphone sound, but in your room, not on your head, get yerself some ESLs!
reg
<edited to tidy up some typos>
