After a previous thread where I stated how much mickey taking I had to endure when I mentioned purchasing a Lyra Dorian, i have finally received it and got it up and running late last week. Just thought I'd share my first impressions 1. The packaging, while neat, isn't over the top and you certainly don't get the impression that a large portion of the cost is down to this - which isn't always the case. 2. The stylus guard is superb, and allows you to easily handle the cartridge, which is nude, and also allows you get it on the arm and perform the initial setup as the cantilever is easily visible with the guard in place. 3. Setting the cart up was the easiest and most hassle free I've yet to encounter doing this. First the stylus guard helps (see 2.) and also once removed the cantilever/stylus is long and thin and is very visible making the alignment very easy. Also the holes are tapered so no need for bolts, just screws, which makes life so much easier. 4. The listening - I've currently got the cart tracking at about 1.9g and got it loaded into the Dino+ at 100 Ohms. The first things were that it was detailed but sounded a bit mechanical and matter-of-fact but after a couple of records it seemed to lose this and started to get better. After about 10 records it was really starting to get going. The treble is excellent while the bass has weight and great attack - vocals have a real in your room presence. but to me the best thing is how the cart just allows you to hear everything going on - and I've played some the most complex orchestral stuff that I've got. This also helps with Jazz records where for the first time I've actually started to really pick out the rythmic communication between the players and this is really where that bass starts to kick in - really tuneful and with great timbre. The main problem with my Linn setup - the cart is on an LP12/Akito going to the Dino+ and then to a tri-amped active Linn Keildihs - is that sometimes you feel the bass but don't really hear it (if you can get what I mean), however with the Dorian the bass has great presence and speed. I've probably put about 25 to 30 hours on the cart in the last 3-4 days and it keeps getting better and better - it is an amazingly addictive cart. I've previously had a Denon DL304 and Goldring Elite on this deck and the increase in cost, so far, is fully justified and I do wonder how much better it would be with a better arm than the Akito. It makes both these carts sound dull and closed in by comparison, and yes I'm aware it costs double the price of the Elite. this has really opened my ears - I did nothing this weekend except listen to record after record and not getting to bed until the early hours - it still sounds detailed and rythmic even at low 1:00 a.m. don't annoy the neighbours levels. Certainly don't regret spending the money on this - but it does worry me if this the bottom of the range what is the Titan like ?
