I'm currently building a 300W Tripath-based power amp from 41hz.com and am thinkinking of placing it inside a custom-built marble case. This will effectively be a 3 sided box with cut-outs for the switches on the front. The heatsink from the amp will form about 2/3 of the rear plate, along with a piece of aluminium with the binding posts and grommets for the PSU input. Is there any reason why I shouldn't use marble and should stick to a metal case? The reason I want to use the marble is that I know someone who can get it made fairly cheaply and I think it will look the B's & E's.
