Hi, I was wandering if anyone could help with some advice. I am planning to make a new case for my Micromega stage 6 as I have just started at a new company and they have water jet cutting facilities. I was thinking of say 8mm aluminium plate cut to form the same size case as the existing then when the work is done having this poder coated. I am a designer in engineering using autocad so the design bit of the job should be straight forward. Is there any tips on the casework that anyone has, like for example lining the internals with copper like the Marantz KI stuff. Also I was thinking at a later stage to have it reclocked so maybe make the case a little taller to make sure I have more than enough space. All ideas welcome. Regards Dave
