Hi Guys I am moving my hifi and need a quick bit of advice. I have a dedicated mains spur which is terminated with 4 MK double mains sockets with built in filters. This was done as part of doing my house up and there was no time to test out whether this was a good idea or not. Because I am moving the hifi to somewhere else in the lounge I have choices as to what to do from a mains perpective as follows: a) get an electrician to move the spur and the MK mains sockets b) get an electrician to move the spur and buy an extension board with filters built in - if so what one? c) get an electrician to move the spur and buy an extension board (MK or B&Q etc) and separate mains filter - if so which one d) forget mains filters and just move the spur I'm not looking for a flame war but would appreciate some good advice as there are differing opinions about what is the right approach. I am really, really busy and do not want to spend hours trying out all sorts of variations that only have marginal differences. Is there a no-brainer answr that the majority sign up to? Lastly, I run my speaker cables through a plastic pipe that is buried in my chimney breast (so that cables are not visible in front of the fireplace) I might need to also run the power cables from my Nuvista M3 power supply to the M3 through the same pipe. Is this likely to degrade the sound to the extent that I would hear a difference? If so then I will get another hole cut. Thanks Dominic
