The Nad S300 integrated defaults to the CD input at power on, which requires an XLR balanced interconnect. As I had no XLR cables, I initially connected the CDP to the Aux. inputs using the supplied RCA cables, but that meant changing the input selection at each power up. As high-end audio store gold-plated, star-dust sprayed snake oil cables are not exactly my cup of tea, I looked for inexpensive XLR cables but all I could find were 5- or 10-m long microphone cables. The only dealer who had 1-m long cables was charging as much for shipping as for the actual cables. So I decided to go DIY. I found at a local store all I needed: [IMG]http://img.photobucket.com/albums/v504/Nadnadnad/XLR-XLRcable002.jpg[/IMG] As connectors were all the same color, I used red heat-shrinkable tubing to tell R from L. Here are the completed 50-cm cables. I used angled connectors at the amp. end as I have very little space at the rear. [IMG]http://img.photobucket.com/albums/v504/Nadnadnad/Completedcables.jpg[/IMG] Success comes at a cost though: 11 € (£7.70) :)
