nsx 10000 crossover points
Discussion in 'DIY Discussion' started by stewartwen, Dec 18, 2006.
  1. stewartwen
    stewartwen
    Aug 16, 2006
    18
    Hithere does any one know the crossover points on a Yamaha NSX 10000. I have tried the usual internet searches but to no avail. There seems to be no tech specs for these l/s.
    This is important for me as I intend to drive them actively.
    Regards
    Stewart
  2. stewartwen
    joel Shaman of Signals
    Jun 21, 2003
    1,650
    sorry to say that I don't have the info you need, although I would guess they're not too far off the NS2000 points.
    Why do you want to go to active xovers?
    joel, Dec 18, 2006
  3. stewartwen
    Tenson Moderator
    Nov 12, 2003
    5,947
    If I were you, I would look inside and see what components are used. You will need to do this anyway to see if it is suitable for a simple change-over to an active Xover. If it has notch filters, ladder delay networks and other things going on then it may not be suitable to just stick a standard active Xover on it.
    Tenson, Dec 18, 2006
  4. stewartwen
    wwhey
    Dec 25, 2008
    wwhey, Dec 25, 2008
