Old cheap powerful amps needed???
Discussion in 'Hi-Fi and General Audio' started by andrew1810, Sep 25, 2004.
  1. andrew1810
    andrew1810
    Sep 20, 2003
    582
    Morpeth, Northumberland
    Hello all,
    Does anyone know where I can get an old amp which is quite powerful 50W+ for less than about £15+p&p
    Sound quality isn't an issue, it is to test the speakers I am repairing and obviously I don't want to risk blowing the Rotel so could do with something expendable.
    Have seen these but I don't think they will be powerful enough:
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=43804&item=5721458626&rd=1
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=43804&item=5721463478&rd=1
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=15241&item=5722294123&rd=1
    Thanks
    Andrew
    1. Advertisements
  2. andrew1810
    Graham C
    680
    Leicestershire
    Just add a suitably high power resistor in the speaker cable. Something like a 50W 4.7 ohm at the speaker end of the wire. You will lose about 4 - 8dB, and the response will be non-flat, but your amp will be safe. Unless you are changing crossover values, I can't see the problem. Any healthy driver should have a DC resistance with a multimeter across its unconnected terminals of about 2/3 of it's rated impedance.
    Graham C, Sep 25, 2004
    1. Advertisements
