Hi Can someone explain what the difference is between Ohms and volts when trying to understand how much output a phono stage has. Is it possible to compare different phono stages' outputs if some are stated in volts and others in ohm? Here are some examples: EAR 834p has a Max output of 30V The EE Minimax has a Maximum Output of 20V The DIY Hifi supply Cole is described as having an output impedance of 600 ohm (but there is no voltage figure). Obviously, the EAR will have a greater output than the Minimax. But how about the Cole, where does it fit in? :rolleyes:
