Power Amp
Discussion in 'DIY Discussion' started by Munkeyboi_Wilde, Dec 4, 2003.
  1. Munkeyboi_Wilde
    Munkeyboi_Wilde
    Dec 4, 2003
    8
    Does anyone have any info on the principles of power amp design?
    I am looking to design and build my own power amp from scratch. Any help would be much appreciated.
  2. Munkeyboi_Wilde
    tom123
    Dec 7, 2003
    46
  3. Munkeyboi_Wilde
    Lt Cdr Data om
    Jun 24, 2003
    1,752
    well if you have to ask.....
    read doug selfs book, and randy slone, the best 2 books on tranny amp design there are.
    john linsley hood, too
    Lt Cdr Data, Dec 9, 2003
  4. Munkeyboi_Wilde
    Munkeyboi_Wilde
    Dec 4, 2003
    8
    Cheers peeps, much appreciated :)
    Munkeyboi_Wilde, Dec 10, 2003
  5. Munkeyboi_Wilde
    Andrew L Weekes
    Dec 2, 2003
    78
    Sevenoaks, Kent
    Yep, good references, but don't expect them to tell you how to make a good sounding amp.
    Self misses the point by a long way.
    My advice read lots, but take nothing on trust and analyse exactly what you are doing. There's rarely any gain without pain and whilst improving one bit, you're often worsening another - use your ears, this is where Self goes wrong ;)
    Whilst I'm at it my advice is start low power, single ended class A, then work from there - you'll soon hear where things start to go wrong, at which point you will then be forced to understand why. Amps with push-pull output stages are much harder to get right.
    Andy.
    Andrew L Weekes, Dec 16, 2003
  6. Munkeyboi_Wilde
    Lt Cdr Data om
    Jun 24, 2003
    1,752
    Self is a bit pompous, ie the only way to an amp is my way, but will give you a great understanding of the functional blocks and topology.
    AS to sound, you can't really engineer it in, it just happens...you design to engineering principles, mathematics, and your sound comes out....there are a few audiophile fokelores....ie mosfets are more rugged, some say tubelike in the sound because the graphs look like a valve, some say they distort more or less, you can put audiophile caps in, resistors in key locations, get your power supply with schottky diodes and posh resevoir caps,
    crucially, layout and earthing arrangements.
    Personally I am inclined to think the things that make an amp measure read perform in engineers speak, performance in a mag usually means sound, so confusion here, kills the sound, the simpler the better, then again, there seem to be no rules.
    I have an amp full of opamps 5534s and tle072s, and it sounds superb. That has changed my thoughts.
    Lt Cdr Data, Dec 27, 2003
