Hi all, Long time since I've posted, but after such a great experience with the t-amp, the DIY upgrade bug has bitten again! I've decided to buy the Monica 2 DAC from DIY Paradise to mate to my Arcam 7SE. From listening to my fathers Derek Shek NOS Dac v2, I can tell that it's going to be a good upgrade, and hopefully should be even better than the NOS Dac from what I read. As I listen to a combination of mp3s and CDs, I would like to use this DAC with both computer and CD sources. As the computer is an optical SPDIF output, I'll be using a converter: [URL]http://www.audioshowcase.com/popupspecs/10tr-08300.htm[/URL] . Are there any known problems with this converter? Will it mess with the sound much? Rather than continually change sources, I was wondering if there was any such thing as a Co-axial switch, or if there are simple schematics so that I could build one myself (easier the better!). Ideally I'd like to have the switch in the box with the DAC. So - is this a crazy idea or might it work? Cheers Mark P.S - I hear that the Monica 2 lowers the CDP output level a bit - will this be an issue with the t-amp, as it isnt exactly the loudest amp in the world!
