I've had this lump .....sat next to my gear not doing anything for a couple of months now. So I decided to take a quick look inside.........! I was not impressed by some of the parts but the actual build quality is very good. So whilst I had the opertunity I hjad a look at the imput board for a start ....thr one thats soldered dirrectly to the rca sockets. I can't sat I've seen that done before ! The rca sockets are really cheap and nasty, so these were replaced by some half decent ptfe insulated ones. The ground was a small tinned copper bent wire....this was lost ad replaced by silver wire. Traceing the signal path on the input board .. it goes through a couple of resistors to the opamp. These were removed and replaced with appropriate Vishay's and the opamp fitted to a good quality socket...it was only a opa 2134 just what I had to hand. The psu for this board uses so standard caps to I added a couple of silmic bypass caps to the main supply ones. The signal goes through a pair of jumper pins ??? I could not work out why yet ....any ideas? the signal is then tasken to the pair of power amp boards via one of the most auwful peices of coax I think I've ever seen and connected with spades.....spades !!! Well this came out asap ....replaced with a twisted pair of 4n silver in ptfe sleeve. I wanted to get the power amp boards out ...but was defeated buy the bolts ...you need an extra long screw driver thats thin. Looking at the schematics ... there is a feed back loop with a opamp that is unusual.....TLc 271 cp........this is a biasable opamp pin 8 and 6 are connected the load on it determins the bias. So the question is can this be swapped for a half decent jobie ? I've to build a speakon adaptor for my current standard speaker cable connections before I can listen but that shouln't take long
