Hi - I've just stepped back into the warm world of vinyl, but am having some problems setting up, and could do with some experto advice. [I've searched the forum without much luck]. Turntable is a Systemdek IIx with an Origin Live fully modded RB250. I've just added a new Sumiko BLue Point Evo III, and playing through my Audio Innovations 800 and Neat Petites the results are stunning .... but only on the outer tracks of an album! Get to the inner third and regardless of record quality, it starts skipping [backwards repeats]. Cartridge alignment is set so the cartridge front is at 90 degrees to the tracks at the middle of the record. Tracking weight is set at the top end of the recommended allowance. Going any higher will defeat the suspension, so I'm loath to do so. The sumiko aparently isn't overly affected by skate, and regarless of setting, it still skips. The arm moves freely and is unobstructed by the raise/lower mechanism. The only adjustment I havent made is VTA: the arm sits slightly lower than parallel at the counterweight end; I haven't fiddled as the sound when not skipping is a great mix of glittering transients and whopping bass [the kettle drums on Peter and the Wolf are awseome]. Could it be that it just needs running in [clutches at nearby straw]? Or do I need to get busy with VTA tinkering. What effect does moving the cartridge back or forth in its headshell have [it's right at the front at the moment]? How do I test if the anti-skate is working properly? Sorry for all the questions - any advice greatly appreciated as I'm loving the valve/vinyl marriage, but many of my fave tracks are near the middle! cheers Jon :)
