[b]Recipe for a DAC Cable........................did you say a duck cable?[/b] Well as we stat to turn our thought to those long winter night. I thought what little project can I provide to lighten those dull moments. The L'Argent Canard Link Recipe for Duck Take one duck ....... This come about one day when I'd mislaided my dedicated 75ohm digital cable, the nearest to hand was a silver twisted pair with cheap RCA's [25p each]. Well suprised at the improved performance I checked all the usual suspect and finally came to the conclusion it was the cable. This by the simple expedient of replacing tit with the Digital cable I had now found. Ingredients 2 x 0.8mm PTFE sleeving 0.7mm dia[internal] 2 X 0.8mm [4n/99.99% purity] Fine silver wire 2 x RCA plugs insulation tape 2 x clamps or a vice soldering iron silver loaded epoxy [optional] Expandable Woven braid [optional] Multimeter Ten minute First sleeve the silver wire in the PTFE. Clamp sleeve and wire to table or bench and clamp the free end [to make a handle]. Using the handle twist the wire to get about 6 - 8 twists per inch. As you release the pressure the number of twists unwind to about 5 per inch. Tape one wire and use the multimeter to locate its other end, tape again. Solder or epoxy RCA plugs in place. Place on a cable cooker* for 2-3 hours till tender. Substitute the Canard for you normal digital link and be somewhat gobsmacked [well I was]. All of the ingredients are fairly commonly available, for a price. If you have any difficulty in getting any of the bits at a reasonable price not more than £15. PM me and I'll see what I can do. A Kit is now available from me Zanash's Patent cable cooker....see another post.
