if im not mistaken the vta is the angle of the cartridge as it rests on the record being adjusted by raising or lowering the arm from its base. the question is, when i bought my rega it had a rega cartridge on there , although one of the cheaper ones i would expect the vta to be correct. i read somewhere that the top of the rb300 had to be perfectly horizontal with the record it was resting on. it wasent.and that made me dubious about the information i was given. i dident mind cos it wasent out by very much. ive since put an audiotechnica (cheep) cartridge as the regas stylus wes buggered and now the angle of the arm is sloping a lot more than it did before. so do i need a vta adjuster and if so how do i know when ive got it right? should the top of the arm and the record be parallel. i know its up to how it sounds whilst adjusting as opposed to any calculated guess and there will be variants with different cartridges ( i think the standard is 17 mm high) but what do i aim for as a guide?
cheers,
Rob,
cheers,
Rob,
