I have recently moved to Mexico from England.
In a nut shell, you can buy FA decent Hi Fi out here.
Mexican domestic electricity is set at 127V at 60Hz, the same rating at the USA; many electrical goods are manufactured/imported from USA.
As England is 230V at 50Hz, I was wondering if I could replace the toroidal transformers in some of my equipment and bring them over following our next homeland visit.
As you all well know, the components within amps, players etc do not run on 230V AC, but are stepped down.
I presume (unless someone tells me different) if I check the output of the OEM 230V toroidal transformer and match it to a suitable version that can operate from 127V AC at 60Hz it should be fine.
Whilst I appreciate there may be some comprise to the overall sound quality, it would at least be better than nothing.
Thanks in advance
Thanks in advance
