small ventilation assembly...suppliers?
Discussion in 'Pro Audio' started by genericaudioperson, Aug 17, 2005.
  1. hello,
    i'm finishing my iso booth this month (got put on hold for a while).
    is there a pre-made vent system you can buy? for example, the vent
    system on the ones at vocalbooth.com have a rectangular external metal
    enclosure that runs up the side of the booth.
    i bought some fans and vents that are quiet and should work, and there
    is a sheet-metal fabricator down the street from me. so i can probably
    pull this off myself.
    but if there is some sort of pre-made thing i'd be interested in
    knowing.
    thanks for any insights.
    1. Advertisements
