Some updates on my audio-visual pattern library :)
Easy all,
These past 2-months I've been working on [_new world], an object-driven library built in Javascript. It uses real-time MIDI data to display audio-reactive visuals in the browser. This week, I developed some new modules for the library, and wanted to share the progress.
Some notes regarding Ableton to Javascript performance:
The performance has surprised me really. As long as memory is being properly allocated between the JS modules, the browser (specifically the V8 engine) is quite a beast. The most used technologies I'm working with are Three.js, P5.js, and a lot of standard HTML/CSS, which each have their own internal handlings for performance. The biggest task on my side for this has been making sure that modules are only imported dynamically via Webpack as-and-when they are available in my composer. For the next month or so, I plan on moving away from handling the composer via JSON, moving to a bespoke-built user dashboard which artists will be able to utilise. The end goal is to allow people to create their own Javascript modules, and then manage a 'live set' environment directly from the interface that I will be building.
Latest demo/insta: https://www.instagram.com/p/CpfwKJaKhnw/
Latest demo/yt: https://www.youtube.com/shorts/FNP2ZhykiTU
Lemme know if you've any questions!
Thanks,
D x
