Spare Rega arm VTA adjuster devices?
Edinburgh
Anyone have any spare Rega tonearm VTA adjuster devices of any sort?
Ideally I'd like just the simple washers that Rega provide, but if you've got something else that does the job I might consider it - the only issue is that deck-specific devices (e.g. Michell's Rega VTA thing) are out unless it's Pink Triangle Export-specific!
I would be willing to pay a reasonable price for such a device if you're willing to let it go...
Cheers,
Dunc
P.S. - Apologies for double-posting to PFM but it's a fairly obscure request so I thought I'd widen the net a tad...
Dunc don't think the michell VTA adjuster is deck specific as such, but it does raise the arm a fair bit at it's lowest setting, they can be had new for about £16 from audiophile candy, or get some washers from an enbgineering shop, they hole needs to be bigger then 23mm for rega arm post.
