SPDIF / AESEBU over CAT5?
Discussion in 'Pro Audio' started by Dirk Bruere at NeoPax, Apr 16, 2010.
  1. Does it work?
    Looking for something around 10-15m
    1. Advertisements
  2. Dirk Bruere at NeoPax
    Mike Rivers Guest
    Are you asking if you can send it through Ethernet, or just through the
    cable used for Cat5?
    The cable is excellent for AES/EBU, and that length wouldn't be any
    problem. Just pick a pair
    (don't try to get fancy and solder an XLR on each end, connected to pins
    2 and 3.
    Mike Rivers, Apr 17, 2010
    1. Advertisements
  3. For now, just the cable.
    Could I send it over ethernet (via a router)? What exists to enable
    that? I can only imagine some uP with an onboard TCP/IP stack.
    I'll probably make up a connector with an RJ45 to XLR on some veroboard
    Dirk Bruere at NeoPax, Apr 17, 2010
  4. Something I have to look at later.
    Dirk Bruere at NeoPax, Apr 18, 2010
  5. Dirk Bruere at NeoPax
    dobie.ian Guest
    dobie.ian, Sep 4, 2013
    1. Advertisements
