nsherin
In stereo nirvana...
Hopefully this next upgrade will be my last for a while and I can then spend some dosh on tunes. The system is pretty much how I want it, but as I listen a lot at very low volumes, I'm looking for a speaker cable that will provide me with more detail and bass.
Current speakers are a pair of Mission m70 that work very effectively in my small room, but I can't always crank the volume up. Speaker cable is QED Original - no banna plugs on them either. Amp is a Yamaha HTR5540RDS.
Don't really want to replace the speakers, as I've got no room for anything bigger, nor a great deal of dosh to spend. Only need two short 2 metre runs. I'll get the cables terminated with bannana plugs when I do go for the cables.
Any suggestions welcomed/apprciated.
Thanks!
Thanks!
