switch needed
rs stock code 320-219 .
These types have a 1·5in. long, 0·25in. diameter spindle, flattened for correct mounting of grub-screwed knobs. Solder tag connections
3 way 4 pole,just use wot ya need
anything else infront of you you wish to give away? How's the homegrown ;)
well mo if you have any use for a pile of paper work your welcome to it
As for the homegrowen :MILD:
penance so wot ya building?
its a power supply for TT.
60va Tx in a box, rectumfrier regulater all inside, 2 feeds to the motor, 33 and 45. hence the switch. The TT isnt finished yet, but i have a nice Scheu 80mm thick acrylic platter and bearing. Probably make the plinth from acrylic with stainless feet:)
penance ya should be able to get the psu finished tommorrow,now how about incorparating some feedback to the power supply from the rotating platter to ensure the speed is always correct regardless:MILD:
