Having given up on my quest to find out what tweeter Tannoy use in their supertweeters, but having had confirmation from Tannoy the the crossovers I bought do indeed come from their ST50's, I'm now looking at buying some suitable tweeters to use with them. Anyone got any suggestions? The Tannoy supertweeters extend to 54Khz, but I've looked at a variety of tweeters most of which don't go that high - not sure what the requirement really is, but I'm assuming that for the crossovers to work well with whatever tweeters I use then the tweeters should have at least similar performance to the ones Tannoy use....?:confused: ? My budget is up to about £65 for the pair, and I have found the following options: Morel MTD-20 (v. cheap at £30 the pair, but only go to 25Khz, soft dome) HiVi Rti.3 (£63 per pair, but only go to 30Khz, ribbon tweeter ) Fostex FT17H (£66 per pair but v high sensitivity at 98.5, but go to 50Khz, horn tweeter) Vifa DX25TG-05-04 (£48 per pair, go to 40Khz, soft dome) Vifa XT19TD-00-04 (£64 per pair, go to 30Khz, ring radiator). i'm tempted to go with the Vifa DX25 as it's competetively priced, extends quite high, and is average sensitivity. Any comments - comparative qualities of soft dome vs horn vs ribbon vs ring radiator?
