- Oct 23, 2004
Following on from the lathing tests, here is the next in the series - Interconnects.
Lots has been written in magazines about the 'sound' of cables and even more can be found on the internet. How much is fact and how much is fiction?
Well, here you get the chance to listen, compare and vote for some different cables without any expectation bias or some pushy salesman steering you down a particular path.
I've chosen four different cables for the test:
- Chord Silver Siren. This employs a silver plated copper twisted pair, teflon insulation and a silver plated outer screen. A 1m pair cost around £150 so a moderately expensive cable.
- Chord Calypso. Entry level 'specialist' cable of coax construction using a stranded copper centre conductor, polythene insulation and copper braid screen. Cost - £30 for a 1m pair.
- Cheap 'bootlace' cable with plastic moulded plugs of the type supplied free with budget audio. Thin copper inner screened with a wrap-around copper screen. Cost - Free.
- One of my own cables built from commonly available parts for a few pounds.
Each cable in turn was placed between my WD phono stage (Rega P9/AT33 source) and the ADC. The same track - UB40 Madam Medusa on 12" single - was recorded through each cable and the files are presented below, with identities disguised in order to enable blind testing.
No changes other than swapping the cables was made during the session.
You can choose two versions, one a short 2 minute excerpt and the other a full 10 minutes.
Please listen and vote for your preference.
I would suggest that identifying differences is more important at this stage that feeling that you have to justify a preference to others. Simply vote for the one you prefer and perhaps say a few words as to what differences you heard.
You can also vote 'no difference' if nothing can be detected.
Names are hidden this time so the voting is anonymous to protect the shy ones here, but please comment if you can.
Short Files:
Cable 1
http://www.mediafire.com/download.php?zvoqtzzyzmd
Cable 2
http://www.mediafire.com/download.php?25zlm1nnmmu
Cable 3
http://www.mediafire.com/download.php?5u3f2wxwzmd
Cable 4
http://www.mediafire.com/download.php?hyrnuytwjcm
Full length files (care - 100mb)
Cable 1
http://www.mediafire.com/download.php?ygt1iyduwyz
Cable 2
http://www.mediafire.com/download.php?5m3mmykmj1n
Cable 3
http://www.mediafire.com/download.php?wvjy1mmrzze
Cable 4
http://www.mediafire.com/download.php?qlzfzyzxejn
Very short files (5mb)
Cable 1
http://www.mediafire.com/download.php?mmzmyynn2jm
Cable 2
http://www.mediafire.com/download.php?jg520jn1nct
Cable 3
http://www.mediafire.com/download.php?0y4mmmj4ozi
Cable 4
http://www.mediafire.com/download.php?mymgitwmzam
Short Files:
Cable 1
Cable 2
Cable 3
Cable 4
Cable 1
Cable 2
Cable 3
Cable 4
Cable 1
Cable 2
Cable 3
Cable 4
