Decided to give this its own thread. I currently have in mind a project to design and build a DAC based on the AKM AK4395VF DAC chip, which is the higher spec version of the one used in the SuperDAC. In order to make this viable, I need other people to be willing to build one or buy a built one. I can't offer any performance guarantees, but with a few things up my sleeve I hope to be able to better the modified SuperDAC for a similar outlay (ie similar to buying a superDAC and modding it). What do you get? I'm planning on designing and building PCBs. In terms of BOM cost, you can decide what you want to put on it in terms of op-amps and caps and regs, etc. The only fixed parts will be the DAC chip (AK4395), DIR (probably going to be an AK4117 for cost and availability reasons over the CS84xx chips) and the logic on the control side. The minimum "kit" that I will sell to people will be PCB, DAC chip, DIR chip and programmed PIC. The question for those interested is what do you want? Do you want an AES/EBU input? How many coaxes? How many optical? Do you want XLR balanced outputs, or just single ended? In self-build, there is no reason that you can't leave the components for balanced output out, saving the cost of op-amps, caps, sockets, etc, if you're not going to use it. It's just a question of what I lay out on the board. Same goes for the inputs, although I will probably only offer one logic set that will assume a full set of inputs. From the self-builders, I need to know what you're prepared to deal with. It is my intention to make the DAC entirely surface mount except for electrolytic decoupling capacitors. Are people happy with that (Imo it gives access to a wider choice of quality op-amps, eg AD8065, AD825, various BB, etc) or would people prefer DIL? So, before I embark on this, who would buy one and at what price? I believe that a full-featured DAC could be built for £250ish, dropping to around £200 if you leave out balanced connections. If I can have 10 people interested then the project could easily go ahead. It could probably work with 5.
