Thought some may find this interesting. It's an intermittent signal on my turntable that has kept me near my wits end for over a year now. I think I've finally resolved it. Problem: No signal in right channel. Solutions after a long time of it oming and going. 1. Tight fit on VDH connect and amp RCA shield damaged the RCA conn on the audiolab pre (no surprise there). So I decided to get some new cables and a phono pre amp. 2. Problem still there. Checked cables. Found a dodgy cable so i resoldered. 3. Problem still there. Rechecked everything, swapped cables, still there. 4. Took pre amp back for check by dealer. All ok. 5. Took turntable to be serviced. Dealer put a new arm tube on my SME free of charge as he thought it was dodgy. Also fitted new cartridge as I originally thought that may be toast. 6. Problem still there. Stripped SME arm. Looked ok. Found that the centre hole to take the signal from the RCA cable was fractionally too wide so the RCA wasn't touching! Crimped connector slightly to make good contact. Reassemble. 7 Problem still there... Continuity checked the arm. Find that the guy who wired it wired the screens of the R & L around the wrong way so I corrected. 8. Problem still there. But now in other speaker!! Did a resistance check down each of the arm tube wires. One of the screens was 100 ohm higher that the other. Re-soldered the offending joint until it was within 4 ohms of the other channel (this actually took a few attempts!). Problem solved! Well that took me well over a year after various 'F*ck it I'll just play CD's' moments. But now I am finally listening to vinyl again. :D Can I get a high 5?
