7_V
I want a Linn - in a DB9
Guys, you will all naturally agree with me that our search for the perfect hi-fi is a quest for the truth - although interpretations may vary as to what is truth.
I'm wondering about Home Theatre though. I was innocently browsing the Speaker Asylum forum (no one's perfect) when I came across a thread about matching subs to main speakers. It led to an article by a guy called Doug Blackburn in SoundStage. I read the article, disagreed with much of it, agreed with some. At the end there was a link to a matching article about subs for Home Theatre in Home Theatre Sound. I read this too.
Now as you know I don't know all there is to know in the field of Home Theatre, although I'm learning. However, this paragraph (detailing differences between the requirements for HT and music subs) stuck in my throat:
... Home-theater subwoofers require a boost in output in the 40-80Hz range to make effects seem real and solid. (Why this is not encoded on the DVDs themselves is beyond me. If the DVDs simply had the boost encoded where it is needed, one subwoofer could serve for both music and movies.) Subwoofers for music need linear response from around 20Hz up to 160-200Hz. Surprisingly, movies are not that dependent on response below 40Hz or so. When there is sub-40Hz content in the soundtrack, there seems to be some built-in augmentation to make those frequencies heard and felt, even on subwoofers that have a hard time going that low. DVD soundtracks played back on music subwoofers with linear frequency response sound a bit restrained and lack the impact and serious amounts of air, floor, and wall motion that home-theater subwoofers can generate. (from an article by Doug Blackburn)
So here are my questions...
Are the requirements for music and HT subs really different?
Should HT subs be 'less than honest' in the 40-80Hz range?
