Turntable to receiver
Hyannis, Ma
Good afternoon; Help, if possible, would be appreciated. I'm old school (as in old school) I'm 80. I want to listen to my vinyl
again. I own a Technics SL-50 turntable. My receiver is a Yamaha RX-A820, which I love! I can program it to do anthing I want
soundwise, speakerwise, whatever. But, and it's a big but, I cannot connect my turntable to it. Apparently Yamaha doesn't think
that Americans or Canadians listen to a real music format, because neither the U.S. or Canadian model of this receiver has a hook-up
for the turntable. Is there a way to hook it up? Any help will be greatly appreciated. Thank in advance.
Biff Kimball
Biff Kimball
Good news, Biff - this is a very solvable problem and you are not stuck at all. What you need is a standalone phono preamp, sometimes called a phono stage. Your Technics SL-50 has a cartridge that outputs a tiny signal called PHONO level, which is much weaker than the line-level signals your Yamaha expects on its regular inputs. Older receivers had a built-in phono stage to boost and equalise that signal, but many modern ones dropped it to cut costs. A small external phono preamp sits between the turntable and the receiver and does exactly that job.
You connect the two RCA cables from your turntable into the phono preamp's inputs, then run another pair of RCA cables from the preamp's outputs into any spare line-level input on your Yamaha, such as CD, AUX, or anything labeled with a name rather than PHONO. Most phono preamps also have a small ground screw on them - your Technics will have a thin bare wire coming from it, and you connect that wire to the ground terminal on the preamp to prevent a hum.
For something reliable and affordable, brands like Pro-Ject, Schiit, Rega, and Cambridge Audio all make well-regarded phono preamps in the 50 to 150 dollar range that would suit your setup perfectly. The Pro-Ject Phono Box or the Schiit Mani are popular choices that people find easy to set up. Just make sure the one you pick is set to MM (moving magnet) mode, which is what a standard Technics cartridge uses. Once it is all connected and you select that input on your Yamaha, you should be hearing your records again in no time.
This is an automated reply from the Audio Forums AI assistant. AI can make mistakes, so please double-check anything important.
Prefer no AI replies to your own posts? Manage your AI reply settings
I hoped it would be something that easy! I'll let you know when I'm up and listening! The first thing I am going to listen to is a 4 record set (live) of George Thorogood in concert from 1982 in Boston. Thank you.
This is my man cave. This is my current set-up. I know, a mish-mash, but believe
me it rocks.
Left to right; Pioneer SX-1500TD
Sony CDP-333ES
Yamaha Aventage RX-A820
Center Speaker SonySS-CT33
Technics turntable SL20 W/Audio Technica cartridge
Pioneer VSX454 (which I'm using for the turntable)
Sony NS999ES
Speakers Bose Inter Audio
Sony SSu-230
Sony Surround Model? (because I have them tied down, and can't see the back.)
JBL Northridge Series N24// rear
Oh, the TV is a Sony Bravia 65". And the other stuff I'm working on.
