what should do with this?
Discussion in 'Cubase' started by The Truth, Nov 1, 2004.
  1. The Truth
    The Truth Guest
    1. Advertisements
  2. The Truth
    Steve Wilcox Guest
    Not bad for a Noob . . . . . .
    First thing - that side stick or whatever it is thats being used as a
    click - replace it with a closed high-hat or tambourine or something like
    that. Try to imagine that you're a percussionist being asked to accompany a
    singer / guitarist playing "Michelle" - what sort of instrument you gonna
    use to provide a nice gentle rhythmic backing to the track ? Bet your life
    you wouldn't choose a horrendous "Click Click Click" on the side of a snare
    If you've got The Renaissance reverb a nice hall reverb on the whole mix
    will sound cool . . .
    Try a Renaissance compressor on the vocals - Start with the presets, and
    adjust by ear, but always raise the output gain until the yellow light is
    just illuminating on peaks - this'll warm things up nicely. . . . PSP's
    Vintage warmer is my current fave on vocals - they may have a demo version
    on their web site if you wanna give it a try . . . .
    I'd also suggest listening to the original track a little more - some of
    your guitar chords are incorrect, and create a dissonance with your voice.
    All the best !
    Steve Wilcox
    Steve Wilcox, Nov 2, 2004
    1. Advertisements
  3. The Truth
    The Truth Guest
    thank you very much my friend
    alex
    The Truth, Nov 2, 2004
    1. Advertisements
