Where can i buy a good quality equipment wire?
Discussion in 'DIY Discussion' started by flyyoung, Apr 13, 2004.
  1. flyyoung
    flyyoung
    Mar 10, 2004
    9
    Leeds
    Currently, I am planning to DIY a valve pre-amplifier. Due to this is my first DIY, I have some questions about the wire i should use inside the case.
    1. Cable from pcbs to RCA(internal), what kind of quality cable should i use? if i use a normal equipment cable, it definitely will loss lots of signal, and it will be meaningless if i am using a good quality RCA interconnect (external).
    2. Cable for power connection, such as in the condition where i need to split the current from the trasformer.
    Thanks
  2. flyyoung
    penance Arrogant Cock
    Jun 30, 2003
    6,004
    Bristol - armpit of the west.
    I use 0.5mm^2 teflon insulated silver plated copper for my valve phono stage, you can buy it from various places. I also use the same but 2.5mm^2 for the power supply.
    You can use silver, i didnt like the use of this for signal hookup as much as the above, but i havent tried it for power conections
    penance, Apr 13, 2004
  3. flyyoung
    flyyoung
    Mar 10, 2004
    9
    Leeds
    thanks, will try to find out where i can get these cables from...
    By the way, do you have any ideas whether i can use OFC cable in "internal case"
  4. flyyoung
    Jun 30, 2003
    6,004
    yup, the cable i mentioned is OFC:)
  5. flyyoung
    flyyoung
    Mar 10, 2004
    9
    Leeds
    Can iyou recommend some sites to get these cable? i still cant find it after half hour of searching
    many thanks
  6. flyyoung
    1,118
    by the cross
    erm why bother,as long as the cable is as good as the p.c.b track to the first component.As for power connections make sure the insulation is suitable rated for the high voltages that could be roaming around in the circuit
    themadhippy, Apr 13, 2004
  7. flyyoung
    Jun 30, 2003
    6,004
    penance, Apr 14, 2004
  8. flyyoung
    Chea Johndle Bizarre Serpent Foomaster
    217
    Foo Central
    Chea Johndle, Apr 14, 2004
  9. flyyoung
    I-S Good Evening.... Infidel
    Jun 25, 2003
    4,842
    In a world of pain
    Farnell FEC 322-2251 (Black)
    Farnell FEC 322-2263 (Red)
    I-S, Apr 14, 2004
  10. flyyoung
    michaelab desafinado
    6,403
    Lisbon, Portugal
    michaelab, Apr 14, 2004
  11. flyyoung
    flyyoung
    Mar 10, 2004
    9
    Leeds
    Thanks a lot. :)
    flyyoung, Apr 15, 2004
