Would someone with a scientific calculator please check this figure?
Discussion in 'Pro Audio' started by Lorin David Schultz, Sep 16, 2006.
  1. +4dBV = +1.8dBm. Is that right? I don't have a scientific calculator
    so I had to rely on a GG search.
    "It CAN'T be too loud... some of the red lights aren't even on yet!"
    - Lorin David Schultz
    in the control room
    making even bad news sound good
    (Remove spamblock to reply)
    1. Advertisements
  2. Lorin David Schultz
    Eeyore Guest
    dBm into 600 ohms ? Definitely not.
    Start - Run - Calc seems to work for me !
    Try using dBu instead there's no confusion then.
    +4dBV = 1.585 V = +6.21dBu
    Graham
    Eeyore, Sep 16, 2006
    1. Advertisements
  3. Lorin David Schultz
    Scott Dorsey Guest
    Try %xcalc -rpn & instead. It's much nicer.
    --scott
    Scott Dorsey, Sep 16, 2006
  4. Lorin David Schultz
    Mike Rivers Guest
    Only if you know into what impedance the V is going into. Forget dBm
    unless you really know what you're talking about.
    My favorite calculator when I need to answer a question like yours on
    line is at:
    http://www.sengpielaudio.com/calculator-db-volt.htm
    Mike Rivers, Sep 16, 2006
  5. C'mon Mike, you know me well enough to know that I *never* know what I'm
    talking about. Besides, I... um, what was I talking about again?
    For some reason I always mix up dBu and dBm. I don't know why I have so
    much trouble with such a simple concept. I meant dBu.
    Cool! That's handy. Thanks for the tip.
    Thanks also to Don and Graham. I appreciate you spending your valuable
    time assisting a mathematically challenged dullard like me!
    in the control room
    1. Advertisements
