Hello again,
Does anyone know of any 93db 4ohm tweeters of good reputation which have either 95mm square face plates, or removable face plates with the face plate fixing holes for the drive unit with a 60.5mm diameter?
I am after something to replace the T33B 4ohm 93db tweeters in my KEF R107. Though my tweeters work, they probably need a service and are the weekest part of the speakers performance (to my ears).
As most may know, the 107 head asembly is a moulded affair which can only accept a specific size drive unit, 95mm square with a 105-110mm? fitting diameter.
As the T33 face plate can be removed, and it has a 60-60.5mm fitting bolt diameter. So it may be possible to retro fit another treble unit to the T33 plate?
Edited to add, it is a 25mm dome, and cloth/soft would be preferable, though I would quite happily fit a Ribbon if it can be fitted with no modification? Though I do not mind widening the drive unit cut out.
Thank you,
Steve
Thank you,
Steve
