This Wiki is not particularly well written
http://en.wikipedia.org/wiki/Active_speaker
But
A`"Powered Speaker" has an internal amp or amps.
In an "Active Speaker" each driver is directly connected to it's own amp and any crossover function is effected at line level - ie before the power amps. The amplifiers and line-level crossover may be built into the speaker cabinet or housed in a separate case or cases.
Arguably a speaker that uses a single full range driver may claim to be active as there is no passive crossover between the amp and the driver.
Well then we need to agree to disagree. I think you need to look at what loudspeaker manufacturers themselves regard as active and passive though.
What it is called is entirely down to the marketing men and what bullshit they think they can get away with and foist on you.
As I said in the old thread, this manufacturer says that to make it simple an active speaker means active electronics is built in it, and that means the amplifier and that can also mean the crossover and multi amps.
You should rename the thread Rob. Can a moving coil loudspeaker ever be active?
It cannot ever be if you base the definition around the use of filters because you always have a passive filter involved.
If we redefine the definition and use the one you used earlier in the thread then people can discuss around that. There are many nuances within the topic.
There is no one definition on this, especially when we start looking at why one approach sounds better or worse than the other and that is surely what matters. It all comes back to filters - how many and where are they positioned in the chain. What are those filters doing and where can they do it best.
Simples remove as many of them as possible![]()
Everything mechanical is a filter, your room is a filter, your ears are a filter, your brain is a filter, why the FFF do you want to create more. Design the mechanical things to do it for you and only use filters to protect things that can't cope with the FFR.
I like it Simon.
