- Feb 14, 2011
Yesterday I purchased a Linn LK85 power amp with the intention of linking it to my existing Majik integrated. The plan was to bi-amp using the Majik for the tweeters and LK85 for the main drive units. I connected it all up and the Majik instantly burnt out part of a circuit board (see previous thread). After reflecting on it I have realised that you can't use the Majik as an integrated and a pre amp at the same time. The options are to use use the Majik as an integrated or a pre amp or a power amp but you can't use the Majik as a integrated amp powering one set of drive units and connect the pre-amp output to a power amp to drive the rest. This is because to use the Majik as an integrated you need to connect the pre-out and power-in terminals and once you have done this you no longer have the facility to connect the pre-out to something else as well. The Majik looks fixable so the question is then whether I should keep it as a pre/control amp only or would I be better off selling the Majik and buying a dedicated control amp such as a kolector for use with one or more power amps?
