Another question on the PSU theme...I presently have +-39vdc and want to reduce this to +-30vdc by adding in some diodes in series (A voltage regulator circuit seems a bit complex). My question is do I have to place the diodes on both rails of the circuit or can I simply place them on the positive rail? If I go for the latter then I presume I will have less voltage on the positive rail than the negative. Is this the case?
