Aeosystem
Hi everybody I wonder if you could help me recently I purchased a second hand jarre aerosystem and the bass is far to much have tried bass boost off and lowered bass on all things I have plugged in and sub speaker looks fine tia gary
What is the configuration of your room? These speakers need to be set in the room away from the walls and especially the corners of the room. If you can indicate your room dimensions including height as well as a description of the surface coverings in the room I can help you better determine if the problem is a placement issue or not. Additionally, have you tried other sources to see if they have the same heavy bass response?
