Analog Balanced XLR Cables?
Hello!
I have one question!
I have now Pangea True Balanced Analog XLR Cables, If I want to upgrade, to another better cables, what should I check out then? I have now Audioquest to my speaker cables Rocket 88 Bi-Wire. It is only the XLR I want to upgrade.
Before you spend more money on an upgrade to what are already "upgraded" cables, I would suggest that you buy (or better yet, borrow) some cheap entry level cables and then have a friend help you do some true double blind listening tests between your existing cables and the $10 variety. I suspect you won't be able to tell the difference between the two.
Then you can use the money you've saved on some new music. :)
Why do you think your XLR Cable with Cardas Grade One Copper and Premium PE Air Tube Dielectric, Triple-Layer Shielding need upgrading?
