Does anyone know where I can get my hands on a spare earth cap for my 8000 p rca input? Was missing when i bought it. They have a common fault of pulling out with tight interconnects.
you can make one easily from a cheap rca plug ....
can remember if it grounds the centre pin or not ...if yes just bend the cheap cable clamp onto the centre pin .
