Audiologica
Audiologica Ltd
- Feb 12, 2009
Special introductory offer on the new Bel Canto entry-level Bel Canto DAC1.5 just £995 (projected price is £1200-£1300)
http://www.audiologica.co.uk/bel_canto_dac1_5.html
Tel: 01403 789226
[email protected]
This model consists of DAC, preamplifier and headphone-amplifier in one bargain package.
The DAC1.5 converts your digital media into music while giving you full control of your system. It provides the most direct connection from your music to your amplifier. Low jitter, low noise and power isolation delivers the startling dynamics in your music.
The Bel Canto Dual-Differential DAC1.5 Control Center features an outstanding 122dB dynamic range and our proprietary low noise digital to analog convertor core. Including five 24/192 digital inputs and one 24/96 USB input, the DAC1.5 integrates and controls all of your digital audio sources. The front panel features a single multifunction control knob that selects inputs and controls volume level for both the main outs and ¼" front-panel headphone jack. The headphone jack is driven by a dedicated DAC/Amplifier circuit that optimizes the output and eliminates any compromises in the main signal path. The DAC1.5 provides remarkable performance, flexibility and control with a simple user interface, easy to read display, full remote control and off-chassis power supply.
The foundation of the DAC1.5 is our jitter-eliminating Master Reference Ultra-Clock circuitry that insures that jitter from any source is reduced below the audible threshold. The 24-bit digital volume control is completely transparent and accurate throughout the volume range. This precision continues with custom 0.1% audio grade resistors, class-A output circuitry and low noise power supply components. The heavy-gauge all-steel chassis design prevents mechanical resonance from compromising the audio signal quality.
Green, low-heat, efficient isolated power supplies and a finely-tuned analog output stage make possible Bel Canto's eco-friendly compact designs; Bel Canto music products are fine instruments that are musically satisfying, discrete and sleek enough to fit any room.
Digital Section:
Maximum Data Input Rate:
24bit Data at 192KS/s:
AES XLR, SPDIF BNC/RCA, TOSLINK
24bit Data at 96KS/s:
USB
Master Clock jitter:
2picosecond RMS
Analog 24/192 DAC Section:
Maximum Output:
4Vrms balanced XLR, 2Vrms RCA
Output Impedance:
200 ohms balanced XLR, 100 ohms RCA
Frequency Response:
20 Hz-20 KHz, +/- 0.5dB
THD+N:
<0.0015%, 4Vrms balanced out, 1KHz
Output Noise:
3.3uVrms A-weighted 20Hz-20KHz
Dynamic Range:
122dB A-weighted 20Hz-20KHz
Headphone Section:
Maximum Output:
138mW
THD+N:
0.01% 35mW, 1KHz
Output Noise:
17uVrms, A-weighted 20Hz-20KHz
General:
Power Usage On:
5W
Power Usage Off:
0.0W
Power Requirement:
100-120VAC, 220-240VAC 50/60 Hz
Dimensions:
8.5" W x 12.5" D x 3.5" H (216 mm x 318 mm x 88 mm)
Weight:
13lbs. (6.5 kg)
Tel: 01403 789226
[email protected]
Digital Section:
USB
2picosecond RMS
Maximum Output:
Output Impedance:
Frequency Response:
THD+N:
Output Noise:
Dynamic Range:
Headphone Section:
Maximum Output:
138mW
THD+N:
0.01% 35mW, 1KHz
Output Noise:
General:
Power Usage On:
5W
Power Usage Off:
0.0W
Power Requirement:
Dimensions:
Weight:
13lbs. (6.5 kg)
