For Sale: Bowers & Wilkins - Cm7 Floorstanding Speakers
For Sale:
BOWERS & WILKINS - CM7 FLOORSTANDING SPEAKERS
I am now selling my B&W CM7 speakers - If anyone is interested, do let me know.
They are only a 5 months old and are in mint condition, boxed as new with all the bits. The finish is a real wood Wenge veneer and look stunning. The sound is really quite amazing with the likes of Naim, Exposure, Arcam, Rotel etc.
Asking £780
Bowers & Wilkins CM7's - Picture 1
Bowers & Wilkins CM7's - Picture 2
Postage will be about £48 insured. (UK) Can send internationally, cost will vary.
Collection is very welcome from near Lichfield, Staffordshire - Can do part distance drive if possible.
Paypal prefered.
Information:
Three-way floor-standing speakers have a reputation for being difficult to design successfully. But not the CM7. Thanks to four decades of Bowers & Wilkins engineering experience, and technology developed in tandem with our 800 Series, the CM7 respects no such reputation. The CM7 is a superbly accurate and revealing wide-bandwidth speaker system.
Like its CM siblings, the CM7's great strength is stereo music reproduction. A high technology, genuine three-way driver line-up, compromising a Kevlar/paper cone bass unit, Kevlar cone FST midrange unit and Nautilus tube-loaded aluminium dome tweeter. These endow the CM7 with an ability to portray musical scale from a whispered lyric to an orchestral crescendo without distortion or compression. The ear-tuned, low-order crossover circuits, made possible by the remarkably wide bandwidth of the CM7 drivers, ensure that music is portrayed as a seamless, cohesive whole. Flowport technology to minimise turbulence, and a bass driver featuring magnet system technology that reduces distortion, mean that CM7 bass is extended, fast and tuneful. An optional port sleeve that modifies the low frequency response allows positioning of the speaker right up close to walls without musical compromise. The CM7's Nautilus tweeter extends the top end all the way to 50kHz and beyond.
The CM7's tall, slim enclosure is a classically manufactured and exquisitely veneered expression of traditional cabinet making and provides a visually understated and mechanically rigid environment for the drivers. Real wood finishes in Wenge, Rosenut and Maple are available. Also, because the black or dark grey fabric grille is magnetically attached, removing it reveals no unsightly grille mounting features.
Technical features Nautilus tube loaded aluminium dome tweeter
Kevlar brand fibre cone FST midrange
Flowport
Description 3-way vented-box system
Drive units 1x 25mm (1 in) aluminium dome high-frequency
1x 130mm (5 in) woven Kevlar cone FST midrange
1x 165mm (6.5 in) paper/Kevlar cone bass
Frequency range -6dB at 34Hz and 50kHz
Frequency response 62Hz - 22kHz 3dB on reference axis
Dispersion Within 2dB of reference response
Horizontal: over 60degree arc
Vertical: over 10 degree arc
Sensitivity 88dB spl (2.83V, 1m)
Harmonic distortion 2nd and 3rd harmonics (90dB, 1m)
<1% 100Hz - 22kHz
<0.5% 150Hz - 20kHz
Nominal impedance 8ohms (minimum 3.0ohms)
Crossover frequencies 350Hz, 4kHz
Bass unit 3rd order low pass
Midrange 2nd-order high-pass, 1st order low-pass
Tweeter 1st-order high-pass
Recommended amplifier power 30W - 150W into 8ohms on unclipped programme
Max. recommended cable impedance 0.1ohms
Dimensions
Height: 910mm (35.8 in) (not including feet)
Width: 200mm (7.9 in)
Depth: 300mm (11.8 in) (including grille and terminals)
Net weight 11.5kg (25.3 lb)
